Input shaft bearing replacement
Old May 15, 2006 | 04:26 PM
clake-maro's Avatar
has anyone replaced their input shaft bearing on a T56? Pulled the tranny to replace the clutch (broken spring wedged in pressure plate) to find that the input shaft was as loose as a wet noodle. Im wondering if you have to tear the whole tranny apart or can you just replace the bearing without setting tedious tolerances.
Old May 17, 2006 | 11:33 AM
roadtrip120's Avatar
Re: Input shaft bearing replacement
Maybe someone else can help out more, but i know you can take off the front cover of the t-56 and put it back on, with out tearing the trany down. Just pull and install. As far as shimming i dont know? Something caused it to come loose/break.. Look into that.. 4th gear is only 200.00 , check "The Gear Box" on ebay, but they have a web site too. Bearing at gm is like 35.00. Not sure how to shim it or check for the proper clearances.
good luck , hope what little info i gave helps
B-rad
importkiller94
Jan 17, 2015 09:03 PM
1996LT1Z28
Dec 1, 2014 01:01 AM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
