i have a ? about abs hookn up on a 12 bolt!!
ok im buying a 12 bolt thats in a 97 camaro, does my 94 camaro have the same abs setup, plugs, ect, as the 97. he said it will bolt right in but he wasnt sure about the abs if the abs would hook right up? so i guess my ? is, is the abs in my 94 the same than in the 97?
Re: i have a ? about abs hookn up on a 12 bolt!!
If you have a wire that goes to a sensor on top of the diff housing you have 3-channel ABS, if the rear has sensors at each wheel it's 4-channel. Check to see if the '97 is the same as yours. I think if the car has traction control, it'll be 4-channel. Not sure so don't shoot me if I'm wrong
. I have a '94 w/out trac control and mine is 3-channel.
carguyshu
Jan 22, 2017 11:19 AM
