HYPERTECH PP3..vs..Transmission re-built
Old Sep 3, 2007 | 02:34 PM
dutss707's Avatar
Doing extreme rebuilt on 4L60E Trans this week.
Have the Hypertech Power Programmer 3 Downloaded and
need to know if I need to Upload program back to stock settings,
or can just leave it. I think I can just leave it as ECM not involved
that much vs. Hardware.?
95Z28/Red/wBlackTtop:Racetronix fuel system , full frontal chassis
rebuilt by Spohn, Global West Traclink etc. Holley 58mm, 38lb injectors. intake by Lloyd Elliot, full race suspension/BeCool rad,
Flexalite 3300 cfm Black magic Fan, etc/etc/....too much to list
Old Sep 3, 2007 | 02:43 PM
2001NBMZ28's Avatar
Are you using it now to increase line pressure? Installing a shift kit? Think you're not supposed to do both at the same time.
Old Sep 3, 2007 | 03:21 PM
dutss707's Avatar
Yes, am installing Transgo HD 2 "modified" shift kit, and line pressure increase.
However, re: Trans, Hypertech re: Trans...only deals with Trans. shift points, and shift firmness.?
Old Sep 3, 2007 | 03:43 PM
2001NBMZ28's Avatar
Had a HPP3 years ago and if I remember correctly it increases "shift firmness" by just increasing the line pressure. Believe there was a warning in the booklet not to do both, and the programmer even asked if a shift kit was installed on the car before trying to change it. I'd return shift firmness setting to stock and talk to your trans builder about using both just to be safe. A 25% increase might be OK but not sure...OBDI/OBDII PCM tuning might be different too.
HarleyZ28
Oct 5, 2015 06:23 AM
colts0455
Sep 4, 2015 01:41 PM
colts0455
Jul 24, 2015 04:51 PM
thenewkid
Apr 12, 2015 07:42 PM
hotrodyou1
Dec 20, 2014 10:05 PM
