hyd clutch system 3rd gen
Old Jun 25, 2005 | 08:45 PM
respectirocz's Avatar
according to my chiltons manual my clutch master and slave cylinder are one unit and are replaced together, i went to the parts store and they have a clutch master and slave cylinder seperate, two seperate parts,
i have no pedal pressure so i went to bleed my system but there doesnt seem to be a bleeder screw on my slave cyl
Old Jun 28, 2005 | 11:49 AM
Re: hyd clutch system 3rd gen
does anyone have a stick 3rd gen??
Old Jun 28, 2005 | 02:31 PM
rngilliland's Avatar
Mine is a 4th gen but I would guess they are the same. If you buy from Chevrolet it comes as a pre blead unit with master and slave. I don't have the bleeding procedure with me but it is basicly remove the slave from the trans and stroke the piston by hand untill there is no air in the system. Don't press the clutch pedal with the slave removed or you can damage the slave. If it was me I would buy the unit from GM instead of the separate parts from the parts store.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
HectorM52
Jan 30, 2015 11:08 PM
Jul 4, 2005 05:00 PM
19redta96
Jul 23, 2002 12:25 PM
