How strong is a 12bolt/9''?
Old Jul 21, 2004 | 09:09 AM
Valkyn71's Avatar
After doing a few launches with my new clutch, and i think messing something up with my stock rear, i know how touchy they are.
So i wanna know how much abuse can a 12bolt or 9'' take? With the supporting drive line, am i going to beable to do a 5000 RPM clutch drop on ET streets and just hold on for the ride?
I know its "shocking" the rear end that breaks them, and id say a 5k clutch drop throwing about 400 RWHP would be considered as quite a shock
But i also know my setup is pretty tame compaired to some people running these rears, so they must beable to take some punishment...
Anyone set me straight?
Old Jul 21, 2004 | 10:05 AM
Red96Lt1's Avatar
Re: How strong is a 12bolt/9''?
9" is stronger, but will rob more HP. I think injuneer is running a 12 bolt with 800 RWHP
Old Jul 21, 2004 | 11:23 AM
rskrause's Avatar
Moderator
I didn't break my 12-bolt with >700rwhp and 5,000rpm launches.
Rich
Old Jul 21, 2004 | 11:26 AM
Valkyn71's Avatar
What is so different about the design on these rears that they can take 3x the tortue the stock 10bolt can? I know a 5000 RPM clutch drop with a heavy clutch and 300 RWHP can destroy the stock rear.
They are basically the same design but beefier parts correct?
Old Jul 21, 2004 | 11:37 AM
IllusionalTA's Avatar
Everything's Bigger.. I haven't seen a 12 bolt's internal's.. I have a 9" and the pinion gear alone is like 3x the size of a stock fbody rear.. Can't go wrong w/ either.. 9" don't have a abs option Unless you run the reluctor on the driveshaft like someone has done.. or you have Traction Control.. 12 bolt is a better option for those who would like to keep their Abs.. The 9" will cause your car to kinda ride like a tank over large bump's.. But on the hwy and all it's transparant.. I have pounded on mine and haven't heard a peep out of it.. Granted it was only 300rwhp.. But a street twin and 5K+ dump's..
Old Jul 21, 2004 | 12:22 PM
rskrause's Avatar
Moderator
There's more to it than just size, but FWIW:
Ford 9"
Ring Gear Diameter 9”
Ring Gear Bolts (10) 7/16” x 20 RH
Yoke/Pinion Spline Count 1.312” / 28, 1.500” / 35
GM "car" 12-bolt
Ring Gear Diameter 8.875”
Ring Gear Bolts (12) 3/8” x 24 RH
Yoke/Pinion Spline Count 1.625” / 30
GM 10-bolt
Ring Gear Diameter 7.5”
Ring Gear Bolts (10) 7/16” x 20 LH
Yoke/Pinion Spline Count 1.438" / 27
Rich
Old Jul 21, 2004 | 12:58 PM
Well there ya go.. But its still bigger..
Old Jul 21, 2004 | 01:10 PM
adrenalinemtr's Avatar
I have a Moser 9" with 4.71 gears, 244/250 Camshaft, MT ET Drags 28X10.5X15, qa1 shock package, Spec Stage 4 Clutch and I launch at 6200RPM. I ran a 11.41 Cam only at rockingham last weekend. I would never trade my 9" for anything and love it. I raised my launch and plan on leaving at 6400 and shift around 7500. Go with a 9" and of course you will need a driveshaft.
Joe
Old Jul 21, 2004 | 01:36 PM
i'm assuming your talking LS1? w/ Rpm's that high a LTx would throw a rod quite far.. Not to mention the puter stop's at 7K.. Are you stock internals' other than the cam? Nice #'s..
Old Jul 21, 2004 | 02:31 PM
Valkyn71's Avatar
Joe
Dam i bet thats quite a rush!
Your stage 4 taking the launches well? Are you pulling the front tires on launch? lol
Old Jul 21, 2004 | 10:33 PM
n20ta2's Avatar
I have a 9 inch in mine with a spool, moser axles, and strange gears,I stall the converter against the transbrake to about 4500-5000 and leave with a 250 shot to the already 500 rwhp with no problems except for a broken torque arm mount. rear end integrity has proven flawless
Mikes 1994 z28
Oct 10, 2015 07:55 AM
WobblySausage
Oct 7, 2015 02:44 PM
WobblySausage
Oct 7, 2015 10:09 AM
Ks0209
Oct 1, 2015 07:32 AM
mmf_1013
Sep 12, 2015 08:56 PM
