How to remove pilot bearing?
Old Oct 17, 2004 | 01:23 PM
BadTexBowtie's Avatar
Is there a tool i can buy/rent to remove this. I made the mistake of not replacing it last time so now i have to after my tranny rebuild. Thanks.
Old Oct 17, 2004 | 05:35 PM
wonbadassz28's Avatar
Re: How to remove pilot bearing?
I used the shaft off of a cheap pulley puller, any bolt that will thread in there tightly will work, once it hits the back of the hole in the crank it will force the bearing out and then u can just pull the bolt out with the bearing on it, like i said any bolt or tap that fits in there snug will do, hope that helps
Old Oct 17, 2004 | 06:52 PM
nateh's Avatar
Materials needed:
water, toilet paper
OR
grease
11 mm 1/4 drive socket and extension or something that is the diameter of the input shaft end
hammer
Pack the cavity behind the bushing with grease or with sopping wet toilet paper.
Put the socket on the extension backwards (for a relatively flat face) and place in the bearing/bushing hole.
Hit the extension with the hammer. If you use the grease, the bushing should come out more easily, but it makes a bigger mess.
If you use the toilet paper, you hit it a couple of times and repack. Repeat.
As the cavity behind the bushing fills, it will hyrdraulically push the bushing out.
This works quite nicely. I like using the toilet paper because when the bushing comes out, it leaves behind damp paper that, when you dig it out, leaves everything clean.
Old Oct 18, 2004 | 02:02 PM
Thanks guys for the info.
Apr 16, 2015 09:57 AM
KYWes
Apr 15, 2015 07:28 PM
BigWil
Mar 29, 2015 12:24 PM
jj_burchiel
Classic Engine Tech
Mar 13, 2015 11:20 PM
