How much will the ten bolt handle?
This is my third camaro. The first was a 12 sec 89 irocz 700r4 that i put about 8 rearends in. The second was a 11 sec 98 z28 a4 that I ran 11.6 in and for a year it held up. My the new one is a 94 m6. So my question how fast before it breaks? I weights 3660 with me in it.
If it does break in then what is a good way to go if your goals are high 11's low 12's? Will a builted ten bolt handle that? I know a 12 or 9 inch will but the cost a arm and a leg.
Re: How much will the ten bolt handle?
In an A4, the ten bolts will hold up to more power, for longer.
The M6 cars are really hard on them because of the launches.
You could put a girdle on it, put a main cap stud kit in it, replace the crush collar with a solid pinon spacer, and weld the axle tubes to the housing and it should hold up longer. Shouldn't be more than a couple hundred dollars to do that.
That's about all you can do to beef up the 10 bolt from what I understand.
Richardan15
May 30, 2015 08:36 AM
Redbird
Aug 26, 2002 10:55 AM
