how much space between driveshaft and tranny is required?
Old Sep 13, 2003 | 03:44 PM
Z95m6's Avatar
i just put my 8.8 in last night and when i put on my reluctor gear on the driveshaft yoke it took up about 1inch of the space between the rear of the housing and the gear. I jacked the rear up to put full weight on the rear and i measured the distance between the Gear and end of housing and it came up to a little over 1/2 an inch. .550 approx. Is that enough room i don't want the driveshaft to collide with the end of the tranny housing. Thanks I will get some pics up when i am done also parts i used to keep my abs.
Old Sep 14, 2003 | 05:57 AM
SABLT194's Avatar
If your planning to launch hard then 1/2 inch should be an absolute minimum IMO. I guess I would pull the rear springs and run the rear suspension through its entire travel range and check your cleareances to be safe. I run 3/4" freetravel clearance when the car is at normal ride height. I'm anxious to hear how these 8.8's hold up. Sounds like a good quiet & strong soultion for street use.
Steve
Old Sep 14, 2003 | 03:08 PM
burnemonm1's Avatar
I have always gone 3/4in. minnimum
revrider
Cars Wanted
Apr 5, 2016 10:06 AM
ryanhilsgen
9
Sep 21, 2015 07:34 PM
z28newbie
Sep 9, 2015 10:26 AM
z28newbie
Cam's maro
Aug 11, 2015 07:45 AM
