How hard to remove rear end
Old Feb 18, 2004 | 11:29 AM
Tumbler96TA's Avatar
Just what the title says, how hard is it to remove the entire rear end from a 96 T/A.
Im having the rear end rebuilt and The two options i have are to pull the whole rear and have it taken to the guy who is doing the work or have the entire car towed there which will run at least $120. I just need to know if im getting in over my head with this.
thanks
Old Feb 18, 2004 | 01:37 PM
IDOXLR8's Avatar
It is not a hard job at all. Just take you time. Everything is pretty much straight forward. It took me less than an hr to remove my rearend.
Old Feb 18, 2004 | 02:29 PM
2001NBMZ28's Avatar
I've done it a couple times on LS1 cars, do it yourself and safe some cash.
Old Feb 18, 2004 | 03:14 PM
Heatmaker's Avatar
Advanced Member
It's easy.... Only hard part is getting hte brake fittings off...especially if yours is rusted out like mine...
Other than that all your rear end is held in is by the rear Shocks,LCA's, TQ arm, DS Yoke... and Panhard rod.
Old Feb 19, 2004 | 08:16 AM
Black6SpdTA's Avatar
Yeah, not too bad. I just got the rear out of my T/A last night. Took about 3 hours but I was working outside in the dark and it was freezing! Not a hard job though.
-Corey
Old Feb 19, 2004 | 08:43 AM
IDOXLR8's Avatar
Did you remover your calipers? Because I did not have to remove any brake fitting when I removed my rearend.
Chet1185
Feb 4, 2015 09:51 PM
jcamaro95lt1
Jan 24, 2015 08:21 AM
nodnarb481
Middle Atlantic
Jan 1, 2015 11:43 PM
ModdedNerd
Dec 25, 2014 05:51 PM
