How do you check alignment between T56 and Engine?
Old Oct 16, 2008 | 06:22 PM
JP95ZM6's Avatar
Question How do you check alignment between T56 and Engine?
I know how to do it if the bellhousing has a round hole at the trans input, like a Hayes for smallblocks. You just put a magnetic dial indicator on the flywheel and measure to that hole while spinning the engine, with clutch and trans removed. But for our T56 bellhousings, there is no hole to measure to. Is a special fixture required, or something?
My TO bearing seems to only have lasted a few thousand miles, so I suspect my new engine block is not exactly like my old one, causing misalignment between the trans and engine. When I install my Mcleod Bellhousing I want to get it right.
Could the front cover of the trans be removed and used as a fixture to do this? How hard would that be?
Old Oct 20, 2008 | 08:36 PM
JP95ZM6's Avatar
Well, I've searched the web pretty thoroughly, and read the T56 manual, with no answers. I'm starting to think I'll need to make a precision fixture that can bolt to the bellhousing if I want to verify alignment.
Old Oct 20, 2008 | 08:39 PM
mdacton's Avatar
Not sure what your working with here.......
sound tricky
Old Oct 21, 2008 | 10:32 PM
JP95ZM6's Avatar
Got an answer from the 'Mcleod SFI....' thread, adding info here for reference:
Originally Posted by 1 DWN CAM
To register this bellhousing you could use a Mcleod bellhousing cap. They are part of their modular bellhousings kits that work with non T-56 transmissions. It's a plate that bolts to the bellhousing with a center register hole in place of the transmission face. That way you would have a way to register the bellhousing. I would use 8702-5 becasue it is the blank cap and above all the least expensive.
teal98
15
Sep 16, 2002 01:23 PM
danielbmx
Aug 27, 2002 11:11 PM
johnsocal
21
Aug 17, 2002 01:06 AM
SilverWS6
13
Aug 14, 2002 09:29 PM
newby
10
Jul 27, 2002 11:39 AM
