How do I pull the axles?
Old 09-08-2004, 12:48 PM
JB_96RS's Avatar
Exclamation How do I pull the axles?
How do I pull the axles on my 96RS? I've got the brakes off and the access plate off but I dont see any C-clips! There are two brackets with two bolts apiece... is that it??
JB
JB_96RS is offline
Old 09-08-2004, 01:22 PM
Chris Wilson's Avatar
Re: How do I pull the axles?
I know that on my 93 formula to get the axels out you have to take off the differential cover, pull the pin that holds the axels apart (have to remove the set screw in it first) and then push the axels towards the inside of the car. Then you can use a magnet to slip the c clips out. You may have to rotate the gear until it is where you can see the set screw. I am not 100% if it is the same on yours but I thought maybe it would help.
Chris Wilson is offline
Old 09-08-2004, 01:30 PM
slayer6x6's Avatar
Yeah, you use the same procedure as listed above.
slayer6x6 is offline
BLK1997Z28
05-07-2015 03:01 PM
4586
01-03-2015 07:22 PM
nodnarb481
Middle Atlantic
01-01-2015 11:43 PM
Dave89IROC
09-05-2002 06:36 AM
Darth Xed
13
07-22-2002 12:45 PM
Quick Reply: How do I pull the axles?
