How do I pull the axles?
How do I pull the axles on my 96RS? I've got the brakes off and the access plate off but I dont see any C-clips! There are two brackets with two bolts apiece... is that it??
JB
JB
Re: How do I pull the axles?
I know that on my 93 formula to get the axels out you have to take off the differential cover, pull the pin that holds the axels apart (have to remove the set screw in it first) and then push the axels towards the inside of the car. Then you can use a magnet to slip the c clips out. You may have to rotate the gear until it is where you can see the set screw. I am not 100% if it is the same on yours but I thought maybe it would help.
Darth Xed
13
Jul 22, 2002 12:45 PM
