how to change axles on 01 SS
Old Jun 30, 2004 | 09:54 PM
ponykiller z28's Avatar
i have a bent axle on my 01 SS and was wondering if anyone knew where i could find a step by step guide through the install of stock replacement axles.
thanks guys
Old Jul 1, 2004 | 12:12 AM
Sweetred95ta's Avatar
can't help u out with the guide, but can give u some pointers. pull the diff cover off and look inside. you'll see a small bolt with the head pointing towards the pass side, i believe. take that out and then it's time to take the pin out. it is the round metal thing, bout the size of a cigar, running through the center of ur carrier. tap on it a little and rotate the carrier and pull it out. then push the axles in (take tires and brakes off of course) and you will see the c-clips in the carrier. they should be loose, depending on how bad u bent ur axles, and pull them out. the axles will then slide out each side. reverse process.
benji
Old Jul 1, 2004 | 12:23 PM
Capn Pete's Avatar
I replied to your question in the "General Tech" Forum . I pretty much said exactly what Benji just said!
Old Jul 1, 2004 | 05:41 PM
thanks guys i really appreciate it
BLK1997Z28
May 7, 2015 03:01 PM
Ringmaster72
Apr 2, 2015 08:32 PM
Cam's maro
Jan 8, 2015 05:01 AM
4586
Jan 3, 2015 07:22 PM
nodnarb481
Middle Atlantic
Jan 1, 2015 11:43 PM
