Holes wont line up for LS? HELP ME
I'm putting my rear end back together, got the axles and c-clips in and went to put the rod that goes in the middle of the Limited slip unit and it wont go in.
Some how the middle part of the LS has moved and partially blocked off the hole. Meaning the hole on the outside of the case doesnt line up with the inside hole.
How do I fix it?!?!! Someone please help me, I'm STUMPED. I've tried turning axles both ways, holding one side and turning the other....
I NEED HELP
Picture sucks but you can tell part of the hole is blocked.
I NEED HELP
Re: Holes wont line up for LS? HELP ME
You need to remove the clips on the axles and slide the axles out of the carrier. Then you need to turn the spider gears that are not lined up to the correct position then re install the axles,clips and pin. Remember to use red locktite on the 8mm pin bolt!
Victor Lamb
Aug 26, 2017 02:52 PM
