Highest rpm's on stock motor?
Old May 8, 2007 | 03:24 PM
mrmint69's Avatar
I believe the LT1 is to shift at 5700 rpm at the stock setting. I can raise or lower it by around 600 rpm's. What is the safest maximum rpm i can run on a stock motor? I have a supercharger so i want to drop my 1/4 mile times without damaging the motor. I get severe tire spin in 2nd gear so i wonder will that get worse if it shifts higher or better?
Old May 8, 2007 | 06:38 PM
LT-x7's Avatar
I run my 100% internally stock LT1 to 6000 rpm and havn't had any problems yet. I normaly shift it in the 58-5900 range but I've nailed the limiter at 6000 more than a few times doing burnouts and such. I don't have the ***** to rev it any higher.
Aside from that, stock LT1's don't really make much power that high. So I highly dout you would see any gains from shifting higher.
Old May 8, 2007 | 07:45 PM
mrmint69's Avatar
With the supercharger, the higher the rpm's the higher the boost so it is when the car makes the most power by far.
Old May 15, 2007 | 11:04 PM
sn8ke eatr's Avatar
my friend revs his m6 lt1 to about 6300. no problems yet but seems a little high to me. btw it has 120k miles on it. my car has 180k and i shift in the neighborhood of 6000, no problem yet
HectorM52
Jul 30, 2017 11:46 AM
blac94Z
Jan 22, 2015 11:19 PM
NewsBot
Jan 11, 2015 06:10 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
