Highest rpm's on stock motor?
I believe the LT1 is to shift at 5700 rpm at the stock setting. I can raise or lower it by around 600 rpm's. What is the safest maximum rpm i can run on a stock motor? I have a supercharger so i want to drop my 1/4 mile times without damaging the motor. I get severe tire spin in 2nd gear so i wonder will that get worse if it shifts higher or better?
I run my 100% internally stock LT1 to 6000 rpm and havn't had any problems yet. I normaly shift it in the 58-5900 range but I've nailed the limiter at 6000 more than a few times doing burnouts and such. I don't have the ***** to rev it any higher.
Aside from that, stock LT1's don't really make much power that high. So I highly dout you would see any gains from shifting higher.
NewsBot
Jan 11, 2015 06:10 PM
