High speed vibrations
Old Sep 15, 2007 | 12:45 AM
96supersport's Avatar
ok 1996 camaro ss, 4:10 gears stock steel drive shaft, i get bad vibrations at about 105 and up, its def. rear end drive shaft related... maybe wheels and tires out of balance?
Old Sep 15, 2007 | 03:49 AM
karpetcm5's Avatar
If you have a steel driveshaft they are notorious for vibrations and especially when you go to 4:10's.
Old Sep 20, 2007 | 12:54 PM
Jason Lauzon's Avatar
Make sure the pinion nut was torqued properly when the 4.10's were put in. If the crush collar is properly crushed to put the proper preload on the pinion bearings it will cause a high speed vibration. Trust me, I know 1st hand.
Old Sep 21, 2007 | 07:01 AM
teke184's Avatar
my vote is for the driveshaft...although that seems to be a higher than normal speed for the vibration.
most guys complain about it at 80-90
BigWil
Mar 29, 2015 12:24 PM
Rde Bandit
Mar 21, 2015 10:17 PM
karnykamaro
Feb 2, 2015 01:37 PM
AlaskaZ28
Jan 1, 2015 12:30 PM
mattszm6
Dec 14, 2014 07:09 AM
