Help with Servo cover, it won't move.
Old 08-02-2009, 06:38 PM
94ZBlk's Avatar
I have 94 Z28 and am installing the Transgo shift kit. I cannot get the servo cover to budge on the side of the transmission. I have tried prying it inward like the video shows, but it won't move. I tried to turn it a little with pliers, no luck. Tapped the snap ring with screw driver and hammer. Still no go. Any ideas?
94ZBlk is offline
Old 08-03-2009, 01:31 PM
LearJet's Avatar
you need to remove the snap ring. Get under it with a pick or a small flat blade screwdriver. It will come off. Then take your pick and catch the O-ring at the bottom of the cover where theres a slot in the case. Stretch the O-ring and cut it and pull it out, cover should be easy to remove then.
LearJet is offline
10-31-2016 11:09 AM
bowtieboy95
07-01-2015 06:49 AM
Jlo
02-03-2015 09:41 PM
HectorM52
01-30-2015 11:34 PM
Quick Reply: Help with Servo cover, it won't move.
