Help With C-Clip!!
Old Nov 18, 2003 | 04:45 PM
96BlackTA's Avatar
Exclamation Help With C-Clip!!
Has anyone ever had problems getting the frigging c-clip off the end of the axle shaft? I've heard some people say they should fall right off but it dosent like that'll happen for me in a million years.
Old Nov 18, 2003 | 05:02 PM
Temple's Avatar
If you haven't already, you need to push in on the axle. Once you do that the c-clip bascally just falls right off. On mine the c-clip just barely hung on and I grabbed it with a pair of needle nose pliers.
Old Nov 18, 2003 | 05:09 PM
96BlackTA's Avatar
I can only move the axle so far in because of that ABS exciter ring and i cant really get enough clearance to grab it with some needle nose
Old Nov 18, 2003 | 05:15 PM
will62085's Avatar
the abs ring should not keep the axles from moving in...u have to push then in from the end where they wheel bolts up...your not moving the carrier, just the axles shafts
Old Nov 18, 2003 | 05:25 PM
96BlackTA's Avatar
the ring I'm talking about is between the hub at the end of the axle shaft and the axle tube so it does interfere.
Old Nov 18, 2003 | 05:49 PM
will62085's Avatar
did the abs rings change in 96?...mine is bolted in between the carrier and the ring gear...do you have a pic of it?
Old Nov 18, 2003 | 06:00 PM
96BlackTA's Avatar
My car has ABS and TCS which might explain the different set-up although I may be wrong. Does anyone who did this on a similarily equipped vehicle have advice please help!!
Old Nov 18, 2003 | 06:45 PM
fastBlack96z's Avatar
I was in the same boat as you not to long ago. As everyone said push the axle in as far as you can. And then rotate the axle. I was stumped when I did mine b/c everything I read said the clip would just fall out mine didn't until I turned the axle.
P.S. Mine also has trac control
Old Nov 18, 2003 | 10:21 PM
Dannno's Avatar
you gotta take the bolt out of the ABS/Trac Control magnet at each end of the housing. Move it out of the way and they'll slide in enough no problem
Old Nov 19, 2003 | 07:39 AM
96BlackTA's Avatar
This turned out to be the solution to my problem thanks for the help.
wrd1972
Dec 14, 2006 01:45 PM
kevm14
Aug 2, 2006 10:17 PM
69gto96z
10
Mar 28, 2006 12:46 AM
VILeninDM
Jan 26, 2005 11:41 AM
kmanRS/SS
Classic Engine Tech
Nov 5, 2003 09:01 PM
