Help is it a blown hydraulic clutch line or what?
Old Sep 7, 2005 | 08:42 PM
Ripped's Avatar
I got a phone call from my son, while at work. All resistance in the clutch pedal went, while he was shifting gears. Car does not go, I guess the clutch doesn't engage.
I called him a tow truck, I have to work overtime, and I don't want to work on the side of the road
It sounds like either hydralics went or the lever is hanging up
any suggestions?
Old Sep 7, 2005 | 09:04 PM
I burn rice too's Avatar
Re: Help is it a blown hydraulic clutch line or what?
I've had the exact same thing happen to me and it was the hydraulic line. Have him look under the car for fluid. Good luck!
Old Sep 7, 2005 | 09:42 PM
Ripped's Avatar
Yeah I phoned him back. He told me that the clutch was disengaged.
I don't know if he's sure or not.
He told me that it was in neutral, no resistance from the pedal
I figure a busted line, and he is misinterpreting what's happened, or the clutch lever/fork is jammed open.
Old Sep 7, 2005 | 10:56 PM
OBE1 95Z28's Avatar
It's helpful to know what year/configuration car. If it's a T56, there's a single bolt that holds the pivot point for the clutch fork. Mine failed and gave similiar results. I've learned to loctite it in place.
Old Sep 7, 2005 | 11:49 PM
Z95m6's Avatar
I'd think if the line busted the clutch would be engaged.
HectorM52
Jan 30, 2015 11:08 PM
Jazsun
Dec 29, 2014 12:14 PM
squarehead
Nov 21, 2014 08:02 PM
dreamer1q
Aug 8, 2002 10:23 AM
