Having trouble getting stock TQ arm to fit on Moser 9 inch
Old May 4, 2005 | 05:53 PM
wicked_95z's Avatar
First off let me say that I'm not going to keep running the stock tq arm Its just that the company I ordered it from is dicking me around so it may not be in for a few days.
Will the stock tq arm mount up? I cant seem to get the holes to line up to drop the bolt down through. Would it be a bad idea to slot the holes to get it to line up?
Old May 4, 2005 | 07:10 PM
OBE1 95Z28's Avatar
Re: Having trouble getting stock TQ arm to fit on Moser 9 inch
If you haven't already, disconnect the front mount of the TA, then install the rear bolts, then re-install the front mount.
Old May 4, 2005 | 08:17 PM
94formulabz's Avatar
I had no more trouble than with the stock 10 bolt. keep trying.
-brent
Old May 4, 2005 | 10:05 PM
wicked_95z's Avatar
I have it completely removed. I think I may have bent it when I scattered the 10 bolt. Would it be okay to slot it?
Old May 4, 2005 | 10:47 PM
respectirocz's Avatar
get a measuring caliper and measure the distance between the holes on the top of the torque arm, the holes on the bottom, and the same for the rear end, there shouldnt be much difference if u measure from the same points each time
if there is some differance then somethings wrong with the either the rear end or the torque arm, if tey're all close enough then you're doing it wrong, keep trying, lol
Old May 4, 2005 | 11:59 PM
1BAD86Z's Avatar
I've never had any problems with the holes aligning. I did have an arm slide out of the mount and through me for a curve for about 30 minutes. I had a hard time getting the control arm to fall into place. Let me know how it goes JOE?
Jason Short
Jan 19, 2015 06:34 PM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
ddr698
Jan 9, 2015 10:05 AM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
