Hard thump / popping sound
1995-Z like new with only 26k miles. Automatic transmission, Car is completely stock. The car runs perfectly and the transmission shifts perfect but it recently started making a thumping / popping sound that's coming from under the car, can feel it come from under the cars floorboard and resonates through the shift lever. Almost Sounds like a transmission mount or rear-end mount that has come lose?
Only happens under heavy load, when I put my foot down on her and she changes or is just about to shift. Then thump!
Any idea what this is?
Thanks,
Thanks,
I'd say your right, tranny mount is a good guess, see if you can push up or sideways on the tranny with your foot. I had one do that, and if you looked under the car from the rear you could see the tail of the trany was moved towards the passenger side a couple of inches...
Originally posted by Rice Eater 316
Yup definetely sounds like a tranny mount. When mine went out on my 97 Z28 A4 it sounded and felt like someone dropped a bowling ball on the floor board.
Should be a fairly inexpensive fix <$100
Thanks,
F'n1996Z28SS
Aug 23, 2023 11:19 PM
