Hard to shift into first and reverse when cold.
Old Dec 14, 2004 | 10:13 PM
izzyz28's Avatar
I've noticed that as the weather gets colder it is getting harder and harder to shift into first and reverse when the car is cold in the morning. I have to literally shove the shifter into gear with quite a bit of force. After driving for a while everything is perfectly normal. Is anyone else experiencing this? Will something other than Dexron III work better and lessen this annoyance?
Old Dec 14, 2004 | 11:49 PM
BlackLT1_TX's Avatar
Re: Hard to shift into first and reverse when cold.
Mine did the same thing last year, it had nothing to do with the shifter nor the tranny. It was the thing that makes sure the brake pedal is in before it lets you shift out of park. Pull the shift selection part of the consol (really easy, two bolts in the consol box and pull up on it, after removing the U clip on the shifter), then unplug the brake release thing. Worked like a charm after that.
Let me know if you need any help.
Old Dec 16, 2004 | 12:45 PM
izzyz28's Avatar
Thanks for the reply, but my car is an M6. Anyone else have any ideas?
Old Dec 16, 2004 | 04:24 PM
1stz28's Avatar
I usually pull mine into a higher gear first to get everything stopped inside the tranny and then grab either first or reverse. I am a bit older and got used to doing that in older transmissions when first wasn't synchronized. Works very well especially with reverse which I assume is straight cut.
Old Dec 16, 2004 | 11:27 PM
izzyz28's Avatar
Thanks, I'll try that. I believe reverse is synchronized on the T-56. There is no grinding or anything, just a lot of effort required. I'll check it out tomorrow morning and see what happens.
Old Dec 17, 2004 | 03:43 PM
Johnnynsac's Avatar
Does your clutch pedal feel spungy? If so, might want to check your slave cylinder for any leaks.
RUENUF
Mar 13, 2016 03:39 PM
dylan1303
May 22, 2015 12:24 PM
armedtrigger
Feb 24, 2015 08:30 PM
Jan 23, 2015 01:13 PM
cmdeshon
Dec 27, 2014 10:06 AM
