Guys with clutch experience
I've had the Cartek clutch for 2 years now, and it's toast. Should I just replace the disk, with another Cartek disk, or should I upgrade the pressure plate, too? Or should I just get another setup? Is there anything else I should replace? I already have an adj. master cylinder. Thanks.
Well if you liked the clutch you can just change the disk.Check your flywhell and pressure plare for exsessive heat marks and warp.If that is the case you might want to take them to a machine shop to reface them.
Rob.
Rob.
Well, luckily I bought the steel billet flywheel from SLP, so I don't have to worry about that for a while. I will check the pressure plate, but should I go ahead and order both the PP and disk?
Sergio
Jan 27, 2016 04:27 PM
Thanks!
