Grinding noise from shifter after new clutch install!
Hey guys, I just got a new clutch (Borg Warner) installed in my '94 Z and now it has a grinding noise in both 3rd and 4th gear coming from the shifter area. It only happens when the RPM's are around 1.5 and I accelerate on the faster side. However, if I accelerate gently and slowly, the grinding in 3rd and 4th gear does not happen. BTW, I do have a Pro 5.0 short shifter in there and that has been in there for the past 2 yrs and made/makes the usual noise that accompanies a short shifter. But the grinding in 3rd and 4th from the shifter is a lot louder now after the new clutch install. Any ideas as to what might be causing this? Might the grinding stop after the clutch is broken in? Any input or help would greatly be appreciated. Thanks in advance.
~~Wes
~~Wes
The links attached are part of a post I was part of a few days ago.
I don't think it was the problem that the guy was having but it may be of help to you.
http://www.chevyhiperformance.com/howto/39021/
and this:
http://www.installuniversity.com/in...er_cylinder.htm
and this:
and this:
and this:
Hey thanks for the help guys. But the second link doens't work. Any ideas on how I could bleed the hydraulics? Thanks again.
~~Wes
~~Wes
~~Wes
