Grinding noise from shifter after new clutch install!
Hey guys, I just got a new clutch (Borg Warner) installed in my '94 Z and now it has a grinding noise in both 3rd and 4th gear coming from the shifter area. It only happens when the RPM's are around 1.5 and I accelerate on the faster side. However, if I accelerate gently and slowly, the grinding in 3rd and 4th gear does not happen. BTW, I do have a Pro 5.0 short shifter in there and that has been in there for the past 2 yrs and made/makes the usual noise that accompanies a short shifter. But the grinding in 3rd and 4th from the shifter is a lot louder now after the new clutch install. Any ideas as to what might be causing this?:confused: Might the grinding stop after the clutch is broken in? Any input or help would greatly be appreciated. Thanks in advance.
~~Wes |
Your clutch probably isnt disengaging all the, thats why that happens. You might want to try bleeding the hydraulics...
The links attached are part of a post I was part of a few days ago.
I don't think it was the problem that the guy was having but it may be of help to you. http://www.chevyhiperformance.com/howto/39021/ and this: http://www.installuniversity.com/in...er_cylinder.htm |
Originally posted by 2000zee28 The links attached are part of a post I was part of a few days ago. I don't think it was the problem that the guy was having but it may be of help to you. http://www.chevyhiperformance.com/howto/39021/ and this: http://www.installuniversity.com/in...er_cylinder.htm Hey thanks for the help guys. But the second link doens't work. Any ideas on how I could bleed the hydraulics? Thanks again. ~~Wes |
Originally posted by newbielt1 Hey thanks for the help guys. But the second link doens't work. Any ideas on how I could bleed the hydraulics? Thanks again. ~~Wes |
