grinding gears
Old Sep 15, 2009 | 02:37 AM
GreenMountain's Avatar
grinding gears
i have a 95 z28 and the gear every thing in the diff is going out. so i was wondering if i could swap out a newer diff from a 2000ish camaro with no problems. is it possible
Old Sep 15, 2009 | 07:48 AM
97FormulaWS-6's Avatar
How do you know everything in the differential is going out? Need some more information.
The rear ends physically are the same in all 4th generation cars, 93-02; but you need to be aware there are different gear ratios, as well as TCS/ABS changes. If you find one that matches your ABS and gear ratios it will bolt right in.
Old Sep 16, 2009 | 02:59 AM
i know every thing is going out because i pulled the cover off and i saw a lot of metal on magnet plus the wear from the grinding. there is also the noise that it makes which is a knocking sound while turning slow
Old Sep 16, 2009 | 09:57 AM
Then the 2nd paragraph that I wrote is what you need to look for, everything else matches.
You should be able to find a used rear axle assembly for like $150 complete; if that.
Just be sure the ABS/TCS are the same, and you know the gear ratios so they are either the same or you can reprogram your computer for the new ratio.
Old Sep 16, 2009 | 10:31 AM
The Untouchable's Avatar
holy chit where are u finding used axles for 150 heck the guy i know at my junk yard want 200 and mine has mad play in the axle shafts and i hear it clunk a lil when im doing bout 30 and i let of and then gently give it gas it clunks and u can feel it
Old Sep 16, 2009 | 02:06 PM
Classifieds, craigslist, etc. People part out cars all the time, and with the stock rearends being basically useless for anything making serious HP they weren't ever hard to find whenever I was looking. Hell, I sold mine for $150 I think when I put my Strange 12 bolt in, that's about all it was worth, even with 3.42s and 60K miles.
Old Sep 16, 2009 | 09:41 PM
i am running the stock 3.23 ratio i think and i want to put 3.73 or 4.11 in it and i was looking into a 9inch or a 12 bolt from moser but i just dont have the money right now
Noenav
Mar 1, 2019 07:38 AM
blkWidow
Apr 21, 2015 01:56 PM
BPS
9
Mar 5, 2015 10:51 PM
willie-d-nice
Feb 13, 2015 06:40 AM
Cam's maro
Jan 30, 2015 09:21 PM
