Good LT1 Clutch Disc?
Old May 26, 2006 | 01:20 PM
  #16
1BadZ95's Avatar
Re: Good LT1 Clutch Disc?
Well it is getting better thankfully. The clutch feels like stock again compared to my other one off ebay. I'm starting to like it more. lol I let you guys no for sure when I get more miles on it.
Old May 26, 2006 | 01:58 PM
  #17
Birdman7389's Avatar
Originally Posted by cmroSS97
my mcleod single disc is junk first i had to pull the tranny after i was all done to shorten the clutch fork fulcrum (the little t-bar that holds the fork to the trans) b/c the fork was contacting the pp and clutch wasn't disengaging now clutch isn't disengaging still. I decided to break it in and see if it gets any better ( only problem is getting it into reverse) well after driving around a little bit it's no better and the other day i slapped it into 3rd and the POS slipped GOOD LUCK with yours
I had none of these issues. Maybe its because you have a big inch LT1 with ported heads and a huge cam?
You shoulda got a ST
Old May 27, 2006 | 02:36 AM
  #18
1BadZ95's Avatar
LOL, well... I couldn't manage to baby it any longer. I got about 75-100 miles on it. Tonight at the "hang out" I ended up getting a run with a white 02 TransAm. Did 3 runs ***** to the wall and the baby grabbed. After the runs I did smell either Brakes or Clutch, not sure which it was but from what I could feel the clutch didnt slip.
Old May 27, 2006 | 11:54 AM
  #19
1 DWN CAM's Avatar
Do you have a dial caliper? The total MAX thickness on the disk should be under.330 thick. Anything more than that will not allow the unit to disengage properly. If your having disk issues Give Don in the reworks dept a call
714 630 2764. Listen to the new Directory select # 4 or 5 for reworks. Don will take care of you.
Old May 28, 2006 | 01:41 PM
  #20
speed_demon24's Avatar
My friends running a cammed LT1 on a 150 shot with the mcleod single disk, and launches it all the time on m/t DR's with no issues, the single disk mcleod is no slouch...
Old Jun 3, 2006 | 02:54 PM
  #21
96SilverZ's Avatar
I've got ~500 miles on mine and it chatters sometimes, but it won't chirp the tires going into second. Just slips a little then grabs. Is this normal? My SLP clutch would bark 'em easy.
Old Jun 3, 2006 | 03:06 PM
  #22
1 DWN CAM's Avatar
Before you put the new disk in did you have the pressure plate re-surfaced?
It's kinda important to have two new surfaces mate each other. If the P/P had heat spots or Hi/Low spots prior to install of new disk you could run into some chatter. Also did you follow the instructions of taking it easy for the first 500 miles so the disk could break in?
Old Jun 3, 2006 | 03:10 PM
  #23
96SilverZ's Avatar
The PP was resurfaced and I drove it to/from work (lots of stop lights) normal for 500 miles...
Old Jun 3, 2006 | 04:20 PM
  #24
91Z-28's Avatar
Originally Posted by 1BadZ95
Ok we got it in but it is real hard to shift. It grabs almost right at the floor. If you pump the clutch a couple of times before you go into first its a little easier but still hard. Whats goin on here?
Got mine in today at it is the same way. Reverse is a BITCH to get into, but other than that I LOVE the way it grabs, I almost don't even need to use the gas pedal to takeoff.
97TA-WS6-Con
Feb 1, 2015 01:01 PM
mattszm6
Dec 14, 2014 07:09 AM
siguy
Nov 27, 2014 10:07 AM
IgorT.455/406
Jun 4, 2003 03:32 AM
