going into reverse
going into reverse
going into reverse is getting difficult, i have to apply quite a bit of pressure to get it into reverse btu once its in their it seems fine.
also a good sized oil leak comes out when i put it in reverse, makin a big ugly mess in the driveway and need it fixed fast
, any ideas??
, any ideas??
Is it possible your reverse lockout solenoid is damaged, leaking, and not allowing the lever to move to the right without strong-arming it?
yeah its really hard to get past 5-6 gear but once its over thier it goes in easy and doesnt popp out at all.
the leak is coming from were the bellhousing and tranny meet, also it seems that sometimes when i drive my transmission will jump up and down a little bit. could it be a mount? or possiblly loose bolts??
If its hard to push the lever to the right, the reverse lockout solenoid is not working. There is a permanent block, that is pulled out by the solenoid. Its posible to force past it with enough pressure. Why not check the reverse lockout solenoid?
http://www.injuneer.com/images/photo...n/T56Conns.jpg
Excessive up-and-down bouncing can be the result of a broken tranny mount.... or loose bolts. Time to crawl under it and check things out.
Is the leak oil (engine rear main seal), or red ATF (tranny input shaft seal)?
The T56 tranny should have ATF in it, which is typically red. There is a cover plate near the starter you can remove and look into, if I recall correctly (my T56 disappeared 8 years ago).
Yes, as Fred said, there is an inspection cover on the lower part of the bellhousing. Unbolt it and feel around in there. If there is a lot of oil inside the bellhousing, then your rear main seal is probably leaking. Try to reach up and feel the top of the bellhousing as well. It's possible your intake is leaking down, but I doubt it would leak that much. Chances are it's the rear main.
RUENUF
Mar 13, 2016 03:37 PM
jimlab
Oct 6, 2002 08:37 AM
