Is going to 3.73s from 3.23s worth it?
Old Mar 22, 2007 | 05:37 PM
Gtpguy's Avatar
Just curious. I know going from 3.23s to 3.42s is a waste of time and money for minimal gains. And it's like going from 3.42s to 3.73s, very minimal or am I wrong? I just don't want to waste $500 on installed gears for only .2 tenths.
I had swapped 3.42s into my old a '91 Trans Am with stock 2.73s and it was a great mod. Especially since I got disc brakes in the process. Had aluminum drums stock.
Old Mar 22, 2007 | 06:42 PM
ZL1modified's Avatar
personaly i would not waste the money...
i started with 2:73 and went to 3:73 and it was awesome... then the pinion gear shattered...
so then i bought a complete 3:42 and didn't notice any differance...
the next time i do gears i WILL be installing 3:23's...
reason 1 being i have more than enough to pull off a decent launch, reason 2 is that i noticed cars with lower gears seem to pull harder, and reason 3 is that they are stronger and i don't have all the money to throw into a 12 bolt...
Old Mar 22, 2007 | 07:32 PM
chevynutman's Avatar
3:42 to 3:73 does not make that much of a difference only time you will notice is top end(like on highway)in overdrive@ 80MPH rpm's will be about 500 different
Old Mar 23, 2007 | 09:34 AM
Z-RATED94's Avatar
.2 tenths is all you might pick up. But then again, that gain is like 2 car lenghts in the quarter mile. You decide.
Old Mar 23, 2007 | 04:39 PM
2000GTP's Avatar
There is probably more cost effective mods you can set your sights on right now.
Old Mar 23, 2007 | 04:59 PM
Gtpguy's Avatar
I have only a small mod list and gears are one of them. Intake, cutout, 3000 stall, 3.73s, 1.7s, OBD1 conversion w/ tune. I would like to hit 12's with this combo, think I can?
Old Mar 23, 2007 | 05:33 PM
2000GTP's Avatar
Its a possibility, but hard to say. If you add a set of headers and some weight reduction into the mix then you should be able to snag some 12sec timeslips.
Old Mar 24, 2007 | 07:50 PM
matLT1's Avatar
3.73???? Man up and get some 4.88's
RUENUF
Mar 13, 2016 03:37 PM
93 RedBird
Nov 15, 2015 08:24 AM
SEOJustin
Sep 24, 2015 04:39 PM
cristian1311
Sep 12, 2015 08:16 PM
blaze309
Sep 8, 2015 05:27 PM
