gm poly tranny mount
Old Feb 16, 2005 | 06:56 AM
tc3's Avatar
tc3
spohn has a gm poly mount, it says no vibration from being the correct hight, is this bs or would it work right?
http://www.spohn.net/product.cfm?productid=1349
Old Feb 16, 2005 | 08:54 AM
valter's Avatar
Re: gm poly tranny mount
It looks very same to ES poly mount. It probably just don't have preload plate. Mine is not vibrating with ES mount + plate. Almost everytime it's driveshaft balance problem.
Old Feb 16, 2005 | 11:16 AM
tc3's Avatar
tc3
yeah but yours is a stick, mine being an auto, would it vibrate still or no?
Old Feb 16, 2005 | 05:09 PM
Deckstripes's Avatar
The mount height changes your driveline angles and the U-joints don't like that. Bunches of people on this board that had their shafts re-done, then swapped back to a stock mount and cured the vibration caused by the poly mounts.
Not every car is sensitive. Ride height, engine mount condition, and manufacturing tolerances on the Xmember, trailing arms, rearend brackets, etc all play a small role. Ride height is probably the biggest. Lots of people have used poly mounts successfully too.
You'll know the minute you put it on if you check the driveline angles. Simple magnetic angle finders are $15. Memory says within 4 degrees is cool, but verify that. Everything I read indicates the spohn mount doesn't use the preload plate. Still a small height increase. But it's an increase that most cars can tolerate.
Personally, I'm not hassling with it. Headed to a GM counter to try and get a 1LE mount. Otherwise, stock replacement. Good luck!
Old Feb 16, 2005 | 06:25 PM
You will be disappointed (unless they have some old stock). The 1LE was changed some time back to the same as the stock mount. There is only one part number that covers both of them now. It is said that the LS1 mount is more like the old 1LE.
Old Feb 16, 2005 | 07:10 PM
Yeah, I heard that about the merged part numbers. Some people think the merged part number is a technology cross-breed between regular and 1LE. Some just think they discontinued the 1LE, no upgrade to the standard. Then there's NOS 1LE at some dealers to further confuse it.
I figure mine's lived through 5 sets of tires in 70K. It doesn't look too great, but if it's replacement does the same, I'd be happy.
You'd sure think there would be more choices. - Later
Old Feb 17, 2005 | 01:28 PM
Ken S's Avatar
I just installed a 1LE trans mount in my 99 Z28 (6 speed manual)
I bought the 1LE trans mount thru SLP back in 1999-2000, and it sat in my garage till just a week or two ago. I could have sowrn it was only $20 back then... (it looks like GM trans mounts are lile $40-60 now?!)
The 1LE and my stock LS1 rans mount looked completely different. My stock LS1 trans mount didn't have any metal on the sides, but had these safety metal plates/"protrusions" that effecitvely kept my tranny still relativley in place even though the rubber was cracked all the way thru... albiet very noisily wth lots of slop (the rubber was completely cracked so it allowed enough movement to hit these metal "stops".. Looking at the 1LE piece, it doesn't appear to have this interlock (unless its hidden inside the rubber).. The 1LE piece though did have seem to have alot more mounting area for rubber metal contact, with metal coming up along the sides for the rubber to attatch to. although it didn't appear there was any rubber to metal contact on the bottom?
1LE trans mount also used a slighly smaller nut than my sotck LS1 transmount. Guy at Autozone figured it out and got me one.
During the install, I noticed i had to every slightly jack the trans up a little higher to get everything to fit(no more than a few mm's i think(... Although maybe just to get the actual bracket underneath to twiddle back on.. After everthing was bolted up, I removed the jack, and double checked the main nut, so it might have settled back down again.
anyways, the 1LE mount works great. Its disturbing how much slop I was dealing with before when my stock mount was slowly cracking over time.
Old Mar 14, 2005 | 01:08 PM
zx1216's Avatar
Does anyone have the spohn tranny mount? I've read the es poly mounts are about .5-.75 inches too high and the spohn claims it is the correct height. If not i might as well get the ls1 mount?
Old Mar 15, 2005 | 10:29 AM
Roadie's Avatar
The ES mount was so annoying that I pulled it out after 1 day. I've had the Prothane mount in my car for 30k miles with no vibe.
Old Mar 15, 2005 | 12:30 PM
CamaroBoy96Z28's Avatar
My prothane has been flawless too.
Old Mar 15, 2005 | 01:12 PM
zx1216's Avatar
Where do you get this "prothane" mount??
Old Mar 16, 2005 | 02:53 AM
lt1form's Avatar
You can get the prothane mount through www.summitracing.com
The picture of the spohn one is the prothane mount.
Old Mar 16, 2005 | 12:30 PM
Roadie's Avatar
I picked mine up from Thunder Racing.
colts0455
Jul 24, 2015 04:51 PM
GT what?
Jul 14, 2015 10:17 PM
Fastbird93
Jul 11, 2015 04:37 PM
Jul 10, 2015 02:23 PM
Noer
Parts Wanted
Jul 4, 2015 05:13 PM
