which gears should i get?
Old Nov 25, 2003 | 12:01 AM
matto1225's Avatar
Ok I have a 94 z28 auto, rebuilding the whole drivetrain, the car has roughly 375 HP, im going to use this car daily but i want really good performance but i wont be running quarter miles with it or racing or anything, i think i have 2.73's on it right now, which gears should i put in there? and which brand, thanks!
Old Nov 25, 2003 | 06:53 AM
Dannno's Avatar
I just made the switch from 2:73's ti 3:73's in a 97 A4. Love it
Old Nov 25, 2003 | 08:19 AM
IDOXLR8's Avatar
Since you are not going to be doing much drag racing then I would recommend going with some 3.42 s
Old Nov 25, 2003 | 09:40 AM
rskrause's Avatar
Moderator
I agree.
Rich Krause
Old Nov 25, 2003 | 10:17 AM
Capn Pete's Avatar
Ditto. I had 3.73's earlier this year, and for daily driving / highway driving, they were a little too much gear IMO. My buddy has 3.42's in his '96 T/A (A4) and they work nice.
Old Nov 25, 2003 | 11:52 AM
JPSartre12's Avatar
Re: which gears should i get?
My 94 Z is my daily driver and I currently have a TH400 and 4.10 combo. To be quite honest, it sucks as a daily driver combo. I have to avoid long highway driving stints and when I do, it's at ~55mph and 3200rpms. Last weekend, I also found out that it wasn't the best drag racing combo either because we bounced off the rev limiter in high gear before crossing the finish line.
Since I want to be able to drive on the highway, I'll probably go with a 3.42 (or Ford 9" equivalent) for next year.
My son also has a 94Z, but his had an A4 in it. He switched from a 2.73 to a 3.73 and was very happy with the change. His ET's dropped by about a 1/2 sec and he was still able to cruise on the highway (OD sure comes in handy). Unfortunately, his 4L60Es didn't perform well at the track, so he's dropping a TH400 in his car over the winter. So, next year, both of us can cruise the highway at 55mph (unless I find a tow vehicle/winter beater ).
Old Nov 25, 2003 | 01:53 PM
IDOXLR8's Avatar
Re: Re: which gears should i get?
Wow 1/2 second is alot. By the way nice time at the track. I am sure that your will hook better at a track like Norwalk. Just curious what kind of numbers did your car put down?
Old Nov 25, 2003 | 02:22 PM
rskrause's Avatar
Moderator
3.42's and a TH400 (1:1 high gear) are good up to about 70-75mph on the highway. I am going to add a GV OD unit when $$$ permits.
Rich Krause
Old Nov 25, 2003 | 03:39 PM
JEDCamino's Avatar
Another vote for 3.42s. That should give you a nice boost without being outlandish. However, I'd say 3.73s would also be ok, but I guess it depends on how much highway driving you do. I plan to put 4.10s in my car after Christmas, but it's ok since I just drive it around town.
Old Nov 25, 2003 | 03:41 PM
JPSartre12's Avatar
Re: Re: Re: which gears should i get?
1.643 60'
6.971 sec 594'
7.434 sec 1/8mile
97.29mph 1/8mile
11.527 1/4et
115.69 1/4mph
LTLHOMER at the wheel.
Old Nov 25, 2003 | 05:26 PM
IDOXLR8's Avatar
Re: Re: Re: Re: which gears should i get?
1.643 60'
6.971 sec 594'
7.434 sec 1/8mile
97.29mph 1/8mile
11.527 1/4et
115.69 1/4mph
I meant hp numbers. Not trying to start anything but Lapeer is a bad track to get accurate numbers. I have heard that the right lane is 6-7mph fast. Just wondering if you knew that. From what I remember your car has great torque down low.
Old Nov 25, 2003 | 06:01 PM
JPSartre12's Avatar
Re: Re: Re: Re: Re: which gears should i get?
No problem. Let's see, I have the printout here somewhere.......
Max HP : 345.7 @6000
Max Torq: 333.2 @5000
Curve starts at: 210hp @ 4000 ~250ftlb
300hp @ 4700 ~330ftlb
~310hp @ 5000 ~330ftlb
~320hp @ 6500 ~270ftlb
My first run was in the left lane: 114.00
Sean's run was in the right lane:115.69
My last run was in the right lane:113.96
Old Nov 25, 2003 | 06:21 PM
93Cam's Avatar
How will 3.42's or 3.73's affect the top speed?
Old Nov 25, 2003 | 06:49 PM
JPSartre12's Avatar
It'll stop me from smacking the rev limiter before the end of the 1/4 for one thing. That can't hurt.
Old Nov 25, 2003 | 06:51 PM
drewstealth's Avatar
If you do quite a bit of highway driveing and not much drag racing i would just get the 3.42. If its the oppisite or you just drive mainly in town then get the 3.73.
