gears for a 383 supercharged?
Old Nov 16, 2004 | 09:41 PM
lillbush5555's Avatar
I did a search and found nothing on this. I am building a new 383 supercharged motor and was wondering if the gears I have in my 12 bolt are to high? I currently have 4.10's. I plan on running around 10 lbs of boost. do I need to drop the gear ratio or will I be fine at 4.11? This car isnt a daily driver but a weekend and strip car.
Matt
Old Nov 16, 2004 | 09:57 PM
rskrause's Avatar
Moderator
Re: gears for a 383 supercharged?
You will likely run out of gear in the 1/4 with 4.11's unless you are building a very high rev motor and run a tall tire. I'd suggest estimating your trap speed, and using the redline of your combo along with tire size to arrive at the optimum gear. You want to be a couple of hundred rpm past peak hp when you go through the traps. Most likely it will be 3.73's or even 3.42's. When I had the M6 I cam pretty close to maxing out 4th at 6,400rpm (with a 6,200rpm power peak) and a 26" tire using 3.42's.
Rich
Old Nov 17, 2004 | 03:13 PM
roguedriver's Avatar
Rich is right. Your probably gonna run out of gear with that setup. With my old 4.10's in my M6 and 26" ET streets, I was going through the trap in 4th at about 6000rpm. That was running a low 12 on the bottle. I'm gonna eventually build a stronger engine that will handle my future setup. An S-trim with the bottle. I went with a 3.73 gear in the 12 bolt in anticipation of that set up. Didn't want to get stuck going into 5th.
Ken R.
Old Nov 17, 2004 | 03:24 PM
SS Mark's Avatar
All motor and any power adder is different when it comes to gears. I would think between 3.42's and 3.73's would do depending on tire size and what rpm you rev to.
-Mark
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
drptop70ss
Mar 26, 2015 01:50 AM
CARiD
Jan 27, 2015 06:27 AM
