Gauge Cluster, or VSS???
Old May 5, 2005 | 10:44 PM
Need4Camaro's Avatar
Basically the speedometer is mostly reading 0. It will bounce around for a second when I hit a bump, or when I bang on the dashboard. It will bounce between 10 and 25 when I'm doing 70 MPH but anything below 50 unless I bang on it or hit a bump will read 0 MPH... I just started doing this right after I installed LED's under the shifter plate. Could I have jarred something? I'm able to get out of 1st gear (A4) with no problems... Whats the likely deal here? Faulty Gauge Cluster or VSS under the transmission?
Edit: Oh btw if it matters, it's a 97 V6 3.8 with an Auto
Old May 6, 2005 | 09:08 AM
Re: Gauge Cluster, or VSS???
Also the cruise control doesn't work...
IndyZman
Oct 22, 2015 02:17 PM
drt
Sep 27, 2015 04:39 PM
mmf_1013
Sep 12, 2015 08:56 PM
RX Speed Works
Sep 11, 2015 03:31 PM
jackpawt883
Sep 10, 2015 08:53 PM
