Front seal pouring fluid
Old Mar 10, 2010 | 04:06 PM
93black-ta's Avatar
I recently installed a used tranny. It worked flawlessly for about a week. Under the advice from a "transmission guy" I added some Lucas treatment to the tranny.
Within minutes of adding the fluid I noticed the dripping from the bell housing (it did not leak a drop before). My fluid was a bit low before I added the Lucas but I assumed I had overfilled the tranny causing the fluid to blow out the front seal.
I dropped the tranny and replaced the seal. I inspected the converter and it had no wear marks, the existing seal looked fine also.
When I put it back together the leak was still there.
Could the front pump just be damaged? If so, what should I look for? I still have my old tranny to use for parts. Is it O.K. to use the front pump from it? (it didn't leak)
Could the honey like Lucas treatment have clogged something causing this blow back?
Thanks in advance,
Curt
Old Jul 12, 2011 | 01:40 AM
Sturgill_SS's Avatar
Re: Front seal pouring fluid
How long did it take you to change out the front seal? And did you have to drop the transmission or just take off the flywheel cover? I may have to do this to mine tomorrow :/
Magenta_Hearts
Mar 29, 2017 08:54 PM
PCLZ28
Dec 24, 2015 05:19 PM
95z_28_camaro_4_Ivan
May 8, 2015 09:56 AM
BigWil
Mar 29, 2015 12:24 PM
Jazsun
Dec 29, 2014 12:14 PM
