flywheel
Old Jul 28, 2008 | 03:57 PM
axehead's Avatar
flywheel
after doing a search i see that i can buy a clutch assembly from the local parts store for about $200 & order a high performance disc (i'm looking at the mcleod single) from thunderracing or etc. i'll have 480rwhp, would my stock flywheel be ok?
thx
Old Jul 29, 2008 | 05:53 PM
Green96Z's Avatar
Do you have a stock bottom end, or an internally balanced rotating assembly? If your bottom end is stock, then the stock flywheel should be fine. A steel flywheel is stronger and slightly lighter, and an aluminum one is a lot lighter, so it will help the engine spin up faster. The only problem with aftermarket flywheels is most of them are neutrally balanced, meaning for an internally balanced engine.
Old Jul 29, 2008 | 09:30 PM
axehead's Avatar
i have a stock bottam end.
Formula Steve
Sep 19, 2023 08:31 AM
Ericksd
Jan 20, 2016 06:07 PM
karpetcm
Sep 29, 2015 10:08 AM
Jake Bialke
Sep 24, 2015 11:31 AM
Bxlt1
Sep 17, 2015 08:31 AM
