flywheel
flywheel
after doing a search i see that i can buy a clutch assembly from the local parts store for about $200 & order a high performance disc (i'm looking at the mcleod single) from thunderracing or etc. i'll have 480rwhp, would my stock flywheel be ok?
thx
thx
Do you have a stock bottom end, or an internally balanced rotating assembly? If your bottom end is stock, then the stock flywheel should be fine. A steel flywheel is stronger and slightly lighter, and an aluminum one is a lot lighter, so it will help the engine spin up faster. The only problem with aftermarket flywheels is most of them are neutrally balanced, meaning for an internally balanced engine.
Formula Steve
Sep 19, 2023 08:31 AM
karpetcm
Sep 29, 2015 10:08 AM
