fluids for rear and tranny?
Old May 14, 2007 | 08:23 PM
one eyed willy's Avatar
i need to do a service on both rear and tranny,what would you reccomened?is there anything else i should do while im under there?
how many quarts will i need of each
should i change out my tranny mount while im down there,dosnt autozone sell a polyurethane mount or something?
Old May 14, 2007 | 08:38 PM
camarolvr69's Avatar
the stock tranny holds 12 quarts...(6 quarts - converter, 6 quarts - trans) but when you drop the pan, you will probably only get like 4 quarts out. Go with cheap Dexron III. For rear, go with a good quality synthetic, you will need 2 quarts of fluid and a 4 oz. bottle of Limited slip additive.
I would check the tranny mount, and if its in one piece, you can leave it alone. But if you really want, you can replace it with a GM piece ~$13, or a prothane ~22...
Old May 14, 2007 | 08:47 PM
Rob1997ta's Avatar
Royal purple
I rec Royal purple in both units.
Old May 14, 2007 | 09:33 PM
i have a 6 speed,so from what i have heard,its 8 qrts,does that sound about right?
so i need about 9 quarts to do both rear end and tranny with some posi additive?
Old May 15, 2007 | 06:02 AM
t56 tranny- 4 quarts dexron III, rear- 2 quarts 75w-90 and additive
Old May 15, 2007 | 11:23 AM
dexron III is better for it than the royal purple stuff?
Old May 15, 2007 | 11:39 AM
no dexron III is just the type/ mix of fluid....any brand of dexron III like RP will do just fine. I dont know what brand fluid is best for t56 since i have an a4.
Old May 15, 2007 | 02:08 PM
2000GTP's Avatar
Do you have reason to believe that your current tranny mount is broken or worn out? If you want to upgrade to poly, its your call, last I heard, Autozone does sell the poly mounts.
jmadoll
May 27, 2015 07:13 PM
BigWil
Mar 29, 2015 12:24 PM
VF-124
Mar 16, 2015 08:14 PM
siguy
Nov 27, 2014 10:07 AM
Snoman73
Nov 17, 2014 07:22 PM
