Flexplate options.
Old Apr 15, 2009 | 11:43 PM
LT1 POWR's Avatar
Flexplate options.
I've got an internally balanced 383 and plan or around 650rwhp with a blower and was wondering what flexplate to get. I know I will need a neutral balanced one, but what about the material and the weight. Should I get a heavier, lighter, or stock weight one, also 168 or 153 teeth. I've got an LT4 starter which I'm hoping will still work with my 383 since its pretty new. Just looking for some opinions.
Old Apr 23, 2009 | 11:31 AM
LT1 POWR's Avatar
Anyone?
Old Apr 23, 2009 | 07:19 PM
rskrause's Avatar
Moderator
There are some very high priced flexplates out there, but I don't see the need for one in your application. Get a cheap SFI flexplate, it should work fine. The less expensive ones are all foreign, and AFAIK the flexplate is the only offshore part in my race car. Even my aversion to cheap foreign parts has a limit, I guess.
Rich
Old Jun 14, 2009 | 07:41 PM
LT1 POWR's Avatar
Whats the stock flexplate weigh? And should I get an equal weight one, lighter or heavier?
Also, if its supposed to be neutrally balanced can it be installed on an internally balanced motor and be alright, or should it be installed and everything spun again to make sure its all balanced?
Old Jun 14, 2009 | 07:43 PM
mdacton's Avatar
it does not matter. you can get the one from jegs for like $60
or just cut the wt. off the stock one with a zip wheel and let them ballance that one.
AviatorDave
Dec 19, 2016 06:35 PM
RUENUF
Mar 13, 2016 03:37 PM
cmsmith
Sep 14, 2015 09:25 PM
cmsmith
Aug 27, 2015 06:37 PM
alphaauto
Jul 26, 2015 04:40 PM
