Finally did it.......
Old Jun 18, 2004 | 03:59 PM
Snowmann's Avatar
I ordered a 3200 vigalante converter, hopefully it will be fun. What 60 ft should I expect. The car runs a slow 2.3 with slicks(13.7 @ 103 ). If I can run a 1.9 60 ft the car should run 13.0-13.1 shouldnt it? Thanks.....CANT WAIT!!!!!!!
Old Jun 18, 2004 | 06:46 PM
MISOMWS6's Avatar
"2.3 '60 on slicks" OUCH That track prep must suck some seroius ***!!!! I cut 1.9xx on stock F1's. Either you are not doing a good burn out to get those babies good and sticky or you are not going WOT on the launch......something aint right Those vigs are underrated I believe that stall will flash around 3700RPM's so you have plenty of stall and a decent STR in that verter to cut some 1.6-1.7ish '60 times, so yes you may see low 13's.
Old Jun 20, 2004 | 04:24 PM
Snowmann's Avatar
The 2.3 60 ft time was without spining (I call deadhooking).Hopefully it is because of the 2.73 and the 98s are kind of know for lacking low end, but it runs great if it can pull 103 in the quarter. Hopefully the vig will fix that slow 60 ft times.
magman
Apr 15, 2016 03:08 AM
PopoFormula
Oct 12, 2015 04:19 PM
9t4lt4z28
Oct 2, 2015 10:28 AM
Ks0209
Oct 1, 2015 07:32 AM
kandied91z
Sep 30, 2015 11:43 PM
