dumb six-speed question...
Old May 25, 2005 | 03:54 PM
cabe_z28's Avatar
when do you know its time to change fluid in an m6 tranny? how often should you change it. and can it be checked? i don't see anything obvious like a dipstick tube like auto transmissions have. thanks in advance.
Old May 25, 2005 | 04:40 PM
Mizz96Z28's Avatar
Re: dumb six-speed question...
I think my Haynes manual says to change it every 10,000 miles or so? 15,000 probably wouldn't hurt but it depends on how you drive I guess. There's 2 plugs in the tranny, one for filling and checking the level and the other is the drain plug. I don't quite remember but I wanna say the fill is on the driver's side and the drain is on the passenger side on my '96 and the only way to really check the condition of the fluid is to drain it so you might as well just change it if you don't know when it was done last. Hope this helps some.
Myles
Old May 25, 2005 | 05:27 PM
cabe_z28's Avatar
thanks brutha!
Old May 25, 2005 | 05:37 PM
OBE1 95Z28's Avatar
No need to change it every 15K. 50K miles would be fine. I usually change it everytime I have the tranny out (clutch replacement). No real need to check the fluid level either unless you have a leak. Fluid level should be even with the bottom of the fill hole located in the side of the tranny.
Old May 25, 2005 | 05:44 PM
cabe_z28's Avatar
well, the reason i ask is that when i am sitting at a light trying to go between 1st and 2nd, it doesn't wanna go into 2nd until i am rolling. so i figured i'd try this first. also, it goes into gear kinda hard at times.
Old May 26, 2005 | 05:40 PM
Janny's Avatar
That doesn't sound too unusual to me. Mine is hard to get in gear quite often. Release the clutch and let the innards spin and it will probably go. If not try again.
surreybrad
Jul 29, 2015 02:55 PM
DDZ/28
Jan 27, 2003 08:54 AM
StealthElephant
3rd Gen / L98 Engine Tech
Dec 14, 2002 01:32 PM
99 LS1 WS6
Nov 17, 2002 10:25 PM
96z
Jul 29, 2002 05:06 PM
