DUAL REAR WHEEL DRIVE??? Fishtailing!!
Old Jul 11, 2005 | 09:47 PM
RSleeper's Avatar
Hey fellas,
I dont know how stupid this question may sound so bare with me im not the most knowledgable guy when it comes to technical detail on 3rd gen cars (specifically "91 RS). Alright, as any 3rd gen. owner knows the rear right wheel has majority if not all the power which cuases the hook/fishtailing effect when ever you give accesive gas on sharp turns or running out the hole. I want to eliminate the problem by simply making my RS dual rear wheel. i know the GT mustangs are Dual i figure i can do the same. I dont exactly know how to go about doing that and if there is anything that will negatively affect the performance of the car if i do so. I heard all chevy rear axles fit, (i.e corvette rear axles) or is there a kit to change this. or is there no solution at all. I'm sure theres a simple solution but this is just not my area when it comes to cars. Thanks for the help. I really appreciate it.
Old Jul 11, 2005 | 10:33 PM
Janny's Avatar
Re: DUAL REAR WHEEL DRIVE??? Fishtailing!!
You need a limited slip differential/posi-trac, or better to get this effect. It is simply a matter of putting different carrier in.
Old Jul 11, 2005 | 11:10 PM
Bow94z's Avatar
yea if you rebuild the rear and install 3:73's and a new posi unit. You'll love the way the car will run. Fishtailing all you want! I am Imagining your car is an automatic?
When i put 4:11's in my car, it was the best mod to date with the madz28 tuning. It really pulls you back into your seat
Old Jul 12, 2005 | 06:29 AM
teke184's Avatar
find a 3rd gen z28, trans am, iroc or ws6 and swap out the rear axles. for the most part (shy of the 4wheel disk break option on some) should bolt right up. and all of those will have a posi rear.
you may be able to find one with better gears too, i know alot came with 3.23s and i'm pretty sure some came with 3.42s
oh and an FYI....posi rears will turn tail on you in a corner if you give it too much gas MUCH easier than your current open differential.
Old Jul 12, 2005 | 08:56 AM
respectirocz's Avatar
not all 3rd gen z28's irocs and other premium f-bodies have a posi
my 87 iroc has an open diff, stock
Old Jul 12, 2005 | 09:23 AM
teke184's Avatar
not saying you're wrong...but are you sure it's not just broken? or a swapped rear?
i could see some of the z28s not having posi, but the IROC???
Old Jul 12, 2005 | 11:16 AM
87DJP2001's Avatar
You heard of options? With special ordered cars some people did not belive in options that did not add to appearance.
Old Jul 12, 2005 | 01:07 PM
teke184's Avatar
i guess i always figured the z28 etc cars came STANDARD with posi...kindda like they come standard with a v8
anyway
Old Jul 12, 2005 | 03:06 PM
87DJP2001's Avatar
anyway
The IROC-Z came standard with 305 Carb or TBI depending on model year. The TPI engines were extra cost options. 305TPI@ $745 and 350TPI@ $1045 so these were not small change options when these cars were new.
Old Jul 12, 2005 | 04:20 PM
Ken S's Avatar
read up on differentials
http://auto.howstuffworks.com/differential.htm
and open differential basically will feed power to the path of least resistance..
I personally like my Torsen T2R differential (tq sensing) but its pricey.
Others swear by the clutch/cone type diff's.. eatons and auburns are popular brands.
some like the locker ones.. but those have to be tough on our tiny 10 bolts.. plus its relatively harsh for the street when turning.
Then there's the spool.. which is basically no differential action at all.. Great for people only interested to go in straight lines.. ALthough if you that serious into drag racing, I can't imagine a 10 bolt lasting very long anyways.
Old Jul 13, 2005 | 12:47 PM
ok, point taken
with both wheels off the ground, spinning one wheel causes the other to rotate in the opposite direction indicating an open diff
but like u said, my posi could be busted, my cone clutches worn out
i'll be sure to let u know whenever i get around to changing my diff fluid
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
blac94Z
Nov 24, 2014 07:12 PM
squarehead
Nov 21, 2014 08:02 PM
FiNSTa
Jul 20, 2002 10:57 PM
