driveshaft for Strange 12 bolts ?
Old May 24, 2010 | 03:42 AM
Sporty-X's Avatar
hello, i'm swapping my rear end for a Strange 12 bolts and want to know if the stock driveshaft lenght will be ok or not ?
If i need a new driveshaft, what are the specs for it and where to buy one ?
Old May 24, 2010 | 05:00 AM
streetbad's Avatar
Stock drive shaft length is good for a Strange 12 bolt with a forged yoke. Billet yoke no.
Old May 24, 2010 | 08:03 AM
97FormulaWS-6's Avatar
I guess it depends. Sometimes it will work sometimes it won't; all depends on the car.
I ordered a new one from www.dennysdriveshaft.com when I put mine in.
Old May 24, 2010 | 07:33 PM
Sporty-X's Avatar
i've written to dennys but havent got any answer.
I wonder if shipping overseas is frightening him.
I'm asking about the lenght because if i need a new driveshaft i want to order it right now to avoid having the car not running and waiting for an overseas shipping for a the new one
Old May 24, 2010 | 10:15 PM
The only issue I see is with trying to order it before you have the axle installed and can make the measurements/check fit is going to be almost impossible. Our cars vary too much to guarantee anything.
I know my driveshaft was 3/4" longer than any driveshaft Denny had made for a 4th gen prior. (Denny's is local to me, about 15 mins from my house). He even had me measure it a few times because he couldn't believe that it was the length I measured.
I would say install it and see how the stocker fits and what the measurements are. I'd say anything else is a shot in the dark.
Old May 25, 2010 | 05:52 AM
AL SS590 M6's Avatar
Moderator
When I put the Strange 12 bolt into my 2000 Formula I used a stock length driveshaft with no problems.
Old May 25, 2010 | 02:33 PM
Strange 12-bolt went into my 94 with stock DS and no problems.
Old May 26, 2010 | 01:02 AM
Sporty-X's Avatar
ok great.
I will put mine back so and check then if i need another one.
Thx
Old May 26, 2010 | 01:11 PM
Just make sure that when the DS u-joint is correctly seated in the pinion yoke, that you have at least 1/2" clearance before the DS bottoms out in the tranny tailshaft housing. Maybe even more with a big HP setup.
RUENUF
Mar 13, 2016 03:39 PM
maybe2fast
Mar 16, 2015 09:45 AM
SABLT194
Aug 21, 2002 07:45 PM
SABLT194
Aug 3, 2002 09:33 AM
