Driveshaft ??s
Driveshaft ??s
At what point do you know you need a new driveshaft. Is aluminum a good choice or will it break when any serious power is put to it and what kind of gains can someone expect out of an aluminum shaft?
Ill scratch the alum. driveut shaft idea, it was just a thought. but anyway how much can the stock ones handle before i should consider a new one. im not sure i want too much more than 400 hp out of this thing.
It's impossible to have a peak of 1.1hp and an average of 1.8.
An average implies that there are some points where it is over 1.8 and under 1.8. But if the peak is 1.1 then it cannot average 1.8.
Unless you are talking about original peak number vs. new peak number.
it did it twice what were the dyno results?
