Driveshaft ??s
Old Nov 26, 2008 | 06:51 PM
Jachin99's Avatar
Driveshaft ??s
At what point do you know you need a new driveshaft. Is aluminum a good choice or will it break when any serious power is put to it and what kind of gains can someone expect out of an aluminum shaft?
Old Nov 26, 2008 | 06:54 PM
sn8ke eatr's Avatar
not sure about strength but i think the alum. driveshaft is like 10-15 pounds lighter, and u pick up 1-3 rwhp. i actually have both so i will weigh them and get back to you if youd like
Old Nov 26, 2008 | 07:08 PM
The steel DS weighs about 16#. The 1LE aluminum is about 12#. The WS6 dyno test showed a 1.1 peak HP gain and a 1.8 avg HP gain.
Old Nov 26, 2008 | 07:32 PM
Jachin99's Avatar
Ill scratch the alum. driveut shaft idea, it was just a thought. but anyway how much can the stock ones handle before i should consider a new one. im not sure i want too much more than 400 hp out of this thing.
Old Nov 27, 2008 | 11:03 AM
Did the 99 LS1's come with an aluminum DS?
Old Nov 28, 2008 | 04:50 PM
sn8ke eatr's Avatar
pretty sure most were aluminum but a few were steel
Old Nov 28, 2008 | 05:02 PM
LSWHO's Avatar
Impossible.
Old Nov 29, 2008 | 12:51 AM
sn8ke eatr's Avatar
Originally Posted by LSWHO
Impossible.
uhh..
Old Nov 29, 2008 | 12:56 AM
camarobird92's Avatar
Impossible.
Why do you say that? The aluminum shaft is lighter, therefore easier to spin, allowing more power to get to the rear wheels.
Old Nov 29, 2008 | 09:24 AM
LSWHO's Avatar
It's impossible to have a peak of 1.1hp and an average of 1.8.
An average implies that there are some points where it is over 1.8 and under 1.8. But if the peak is 1.1 then it cannot average 1.8.
Unless you are talking about original peak number vs. new peak number.
Old Nov 29, 2008 | 01:31 PM
Oh... I see what you are saying. I didn't really look at his numbers very close. I thought that you were saying that it's impossible to see any RWHP gains from the aluminum shaft... Sorry...
Old Nov 29, 2008 | 03:43 PM
Kevin97ss's Avatar
I think he meant a 1.1HP gain at peak horsepower and a 1.8HP gain through the power curve. If I remember corectly it was also around a 5ft/lbs gain through out the torque curve.
Old Nov 30, 2008 | 12:46 PM
Exactly
Never cease to be amazed by what gets posted around here.
http://www.ws6.com/mod-1.htm
Old Nov 30, 2008 | 01:54 PM
slowride94z's Avatar
Is it impossible to answer your question?
Old Nov 30, 2008 | 05:08 PM
sn8ke eatr's Avatar
^ that link causes my internet to freeze.. it did it twice what were the dyno results?
