Driveshaft length problem.
Old Jun 20, 2007 | 06:38 PM
94zrag's Avatar
I bought a used denny's d-shaft off another board. Didn't know the length when I bought it(didn't really care since I knew I could resell it for what I bought it for, if I need too). Here's the issue: The shaft itself is the same length as stock u-joint centerline to centerline(which is the length I need), however the yoke that goes into the transmission is 3/4'' shorter than my stock one. Would this put too much stress on the output shaft of the tranny?
If it won't work, does anybody need a nitrous ready 'shaft for around $300
Old Jun 20, 2007 | 06:48 PM
mdacton's Avatar
the yoke should bottom out then pull it back out 3/4" thats about where it should be...what yoke is it? strange?
I know some yokes they cut down....the strange yoke for a 1350 is really long
Old Jun 20, 2007 | 07:24 PM
94zrag's Avatar
I can't test fit it right now, The drivetrain is out of the car.
As for the yoke, I assume it's whatever denny's uses
it doesn't look like it's been cut down at all.
13qtr
Oct 28, 2016 08:11 PM
FredM
Exhaust System
Feb 8, 2016 02:10 PM
ryanhilsgen
9
Sep 21, 2015 07:34 PM
POLOVETTE 94
Aug 21, 2015 07:11 PM
realistyc
Jul 28, 2015 07:32 PM
