Driveshaft Length.
Old Aug 6, 2007 | 07:57 AM
mustangmuncher's Avatar
Driveshaft Length.
I have the Moser 12 bolt in (1350 yoke) and did the u-joint conversion, and the driveshaft wouldn't go in, until we put the tranny jack under and lifted the rear about 2 inches, but it barely fit in. Had no play, and I didn't want to risk bringing it down to ride height because it would have bound up for sure. Is there a standard amount shorter the DS needs to be?
Old Aug 6, 2007 | 08:04 AM
NVetro's Avatar
It somestimes works, and sometimes doesn't with the stock DS. The stocker form middle of the yoke on one end to the middle of the yoke ont he other end should be about 42". Looks like it mite be alittle to long, on a hard launch you could risk damaging your trans as the shock will bang the hell outta the point int he trans the yoke is hitting. You should have 1/2" to 3/4" of play in the driveshaft from front to back when its disconnected from the diff and still in the trans. Pretty much you take off those 2 straps holding the ds on the rear and slide it back and forth, should be about 1/2" to 3/4" of play, some say 1" on higher HP applications. I forget if you test it with the car on all 4 wheels or not, someone chime in please.
Old Aug 6, 2007 | 05:25 PM
You want the car at the normal ride height to measure the play in the slip yoke.
Old Aug 6, 2007 | 08:03 PM
Thanks Injuneer, needs to be an inch shorter. Can't wait for tomorrow.. now to figure how im going to go about fixing the speedo..
RUENUF
Mar 13, 2016 03:37 PM
Henson071
Dec 30, 2015 09:55 PM
ryanhilsgen
9
Sep 21, 2015 07:34 PM
95z_28_camaro_4_Ivan
Aug 25, 2015 03:59 PM
realistyc
Jul 28, 2015 07:32 PM
