Driveshaft length and 12 bolt?
Old May 13, 2008 | 06:40 PM
69gto96z's Avatar
I am thinking about ordering a Denny's Nitrous Ready Driveshaft. Mine is out of balance, again, and I dont see the point in spending any more money on it. I am using the stock 10 bolt right now, but am going to go to a 12 bolt later on. Will the driveshaft work on a 12 bolt also?
Old May 13, 2008 | 10:46 PM
97 RedSS's Avatar
Id wait until you got the 12bolt and go to denny's website and do the measurement sheet he has so your DS will be the perfect length.
I went with a N20 ready shaft and its awesome. No viration at 80mph like all my other Drivshafts....
Old May 14, 2008 | 08:15 AM
AL SS590 M6's Avatar
Moderator
With my Strange 12 the driveshaft is the same as a 10 bolt.
Old May 14, 2008 | 09:01 AM
NVetro's Avatar
With a Moser 12 bolt my stock legnth denny's nitrous ready ds makes the clearance a little tight, you want 1/2-1" of play, closer to 1" for higher hp applications....get it a little shorter then stock. I THINK (you have to search for forums for this) the stock DS is 42 1/2", 42" mite be better or 42 1/4"
Old May 14, 2008 | 10:19 AM
mzgp5x's Avatar
I had a Denny HD shaft (97ss Camaro 383 - D1 - M6) with a modified gm 10 bolt. I broke it. The drive shaft was a good piece. Then I went to a Moser 12. It had 1350 yoke. I talked to Denny to alter, but, the shaft could not be altered due to cutting within the HAZ of the weld. So, I purchased a new Denny HD with 1350 yoke. All of their drive shafts are quality parts. Hope this helps. B.
Old May 14, 2008 | 11:50 AM
69gto96z's Avatar
Awesome, thanks guys. I will probable just try and find a used steel one for now, and then when I get the 12 bolt get me a nitrous ready driveshaft.
Old May 16, 2008 | 05:39 AM
Daniel6718's Avatar
tyan dont do a 12 bolt...do a 9 inch....no need to break a 12 bolt....
Old May 18, 2008 | 10:42 PM
69gto96z's Avatar
Ha very true
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
maybe2fast
Mar 16, 2015 09:45 AM
ddr698
Jan 31, 2015 10:58 AM
