Drag Slick??
Old Mar 1, 2006 | 05:56 PM
JAG05's Avatar
Drag Slick??
I plan on going to the drag strip this weekend. And I was thinking about putting a slick on my car for a few passes. What are the chances of breaking something with an A4??
Old Mar 1, 2006 | 07:54 PM
Jeremy95TA's Avatar
Re: Drag Slick??
You sig doesn't say that you have a converter, so the shock shouldn't be too bad on the rear. Also, any time you go to the track you run the risk of breaking something i.e. the rear. I have lots of friends running 11's and lower at the track on slicks and they have made numerous passes. However, their rears are giving out. I don't think that one time at the track will kill the rear esp since I don't think you'll see anything better than a 1.8 60'.
IMO, I think that your car will be fine to make several passes with slicks, but you always run the risk of breaking when at the track. Also, it depends on what kind of shape your rear is in. Your car is 12 years old. Sorry my post didn't really answer anything, but I hope it helps.
Old Mar 1, 2006 | 09:02 PM
StudyTime's Avatar
Re: Drag Slick??
My first night on slicks I broke, but my car is a six speed and that was with an aggressive aftermarket clutch.
On the other hand, a friend's 9 second car has cut 1.5x 60' times on his stock rearend with a stroker and a converter that stalls to 5,000+ rpm.
There is no clear cut answer except for, do not run slicks unless you're prepared to fix a broken drivetrain component if you experience failure.
Ben T.
Old Mar 2, 2006 | 11:07 AM
camaro81's Avatar
Re: Drag Slick??
You shouldn't have any trouble at all, hell you really shouldnt even need slicks with those mods unless your running lower gears or a converter.
Thats the perfect answer though
Old Mar 2, 2006 | 12:11 PM
TQdrivenws6's Avatar
Re: Drag Slick??
Most tracks require a loop on any car running slicks...
DR's should be more than adequate for your setup.
Old Mar 2, 2006 | 12:45 PM
JAG05's Avatar
Re: Drag Slick??
Well its a small town drag strip. 1/8th mile. Theres not that many people looking at safety stuff.
Old Mar 2, 2006 | 02:05 PM
IHI's Avatar
IHI
Re: Drag Slick??
And that is the mentality that will get you or guy in the other lane hurt or killed.
The safety rules have been implemented due to others unfortunate situations and are there to protect more than you. Do yourself a favor and if going to run stickey tires, adhere to the rules. Too many guys would administer a class A azz whoopin on some hack that just tore up an opponents car or hurt another driver/spectator due to being cheap/stupid or felt like gambling with others well being.
Not trying to sound like a pre madonna either, but anytime you have cars on a race track going ballz out no matter how fast/slow-**** happens. I seen a car do a 360 in teh middle of the track one night...she was only running low 9's in teh 1/8mi.
Old Mar 2, 2006 | 09:45 PM
IdahoLT1's Avatar
Re: Drag Slick??
Theres the problem .
j/k
RUENUF
Mar 13, 2016 03:37 PM
HAWG
Sep 25, 2015 11:41 AM
94ZinEdgewater
Sep 8, 2015 09:55 PM
