drag radials
Old Apr 8, 2004 | 08:12 AM
jasonss's Avatar
drag radials
putting 285 nitto drag radials on my 00 ss 6 speed, and going to the track tommrow, think my rear end will be alirght, car dyno at 338 rwhp and 350 rwtq, any tips
Old Apr 8, 2004 | 08:27 AM
CrippleFightin's Avatar
Yeah you should be fine with just Nittos. You wont get great traction, just better than street tires.
Old Apr 8, 2004 | 06:37 PM
cndctrdj's Avatar
if they wont give you great traction what will. my biggest problem in my car is traction, i average 2.4 60' how am i going to get those times down without better tires?
Old Apr 8, 2004 | 11:04 PM
chpmnsws6's Avatar
2500rpm...... slip for a half a second till you get rolling then dump the clutch and nail it
Old Apr 8, 2004 | 11:29 PM
Black01_Z's Avatar
Nittos wont give u any traction to brag about Get a girdle cover and toss some BFG DRs on it for traction. They'll grip and your rear should hold for a while with a girdle.
Old Apr 9, 2004 | 06:38 PM
cndctrdj's Avatar
im gonna have to go try this
ill get back later and tell you how bad i did
Old Apr 10, 2004 | 12:26 PM
chpmnsws6's Avatar
the reason you let it slip for a milla second is so the gears can mesh before you put 350+ torque to em. if you launch hard thats 350+ pounds of torque making the pinion gear slap the ring gear and on a stock 10 bolt it = pushing ur car off the track
i rather cut a 1.9 than trying for a 1.8 and then hafta push the car off the track
RUENUF
Mar 13, 2016 03:37 PM
HAWG
Sep 25, 2015 11:41 AM
94ZinEdgewater
Sep 8, 2015 09:55 PM
